ALL....Thanks a lot for the info. I'll go with red wheels etc.. Still looking for a Martin Senour dealer. Turns out upon inspection I have a 550 engine cover inasmuch as it has the oval indent on the side. On the hours, I'll have to assume it has had several rebuilds if 3-5000 hrs is the interval and in view of its excellent performance. I assume the 20,000 is correct 'cause the 2 is at the far left space. I had thought that it was reasonable after doing some arithmetic and concluding it corresponded to about 2 hrs per day for the 32 unknown years of its life. On a gas engine, 20447 hours is about 15000 hours overdue for a complete rebuild. If the hours are 2044.7, it is reasonable to rebuild it at about 3000 hours, I've seen them go to 5000 hours on gas engines but that is rare without a rebuild. Diesel can go past 5000 without skipping a beat. As for the paint colors, tractor should be green, grill should be yellow. The vertical center portion of the grill most likely should be red with yellow letters, the wheels should be either red or green. . .both were common . . .I've seen both on complete restorations and nobody seems to know what is correct. I have a 1955 and when I sandblasted the John Deere yellow off the wheels we found green paint on the wheels. I repainted them red because I already had a gallon of the correct Martin Senour and didn't want to waste it, besides I think the red looks better. . .but near as I can tell, the color choice is yours. : : : : I trust that it is actually 2044.7 hours, if not 20K hours is considerable. A lot depends on the maintenance and use, I had a 1955 Super 55 w/ less than 2500 hours where a rod came through the block. You just never know... : : : : : : : I recently bought a 1956 Super 55 and have found it to be just what I need. It seems to have been a Florida tractor and some time before the last owner was "fixed up" and moved to Michigan. It has been lightly used for the last 10 years. Two questions....Is 20447 hours a lot, a little, or average engine hours? What is the correct color scheme ( it currently is green with white grill and wheels)? Doug : : All the Super 55s I have seen are green with yellow grills. I have seen green wheels and red wheels, but not white. Sounds as if someone painted a Super 55 with the 550 colour scheme.
