Filter adaptor
VADAVE
05-19-2008 15:13:08
third party image
This is my 1855 with the oil filter adaptor I purchased from John Parker. He advertises in both the HPOCA magizine and Oliver Hertiage. So far it seems to work pretty well and is a simple conversion.
Dean Barker
05-22-2008 20:43:46
 Re: Filter adaptor in reply to VADAVE, 05-19-2008 15:13:08
I buy a filter base from a salvage yard for a gas engine. There are Fleetguard filters available for the fitting that comes with the filter base or you can change to the fitting that is used with the long O/U filter and use a bigger, more readily available Fleetguard filter.
Converted both of my 1655 diesels that way.
Don-wi
05-20-2008 13:42:20
I just put that adapter on our 1855 last year. Haven't done an oil change since then yet but it should be a little easier now instead of the old sock filter...
Donovan from Wisconsin
Larry NE IL
05-21-2008 21:25:16
 Re: Filter adaptor in reply to Don-wi, 05-20-2008 13:42:20
Wonder if that will fit my 1655? I"ll give them a call.
Don-wi
05-25-2008 08:07:03
 Re: Filter adaptor in reply to Larry NE IL, 05-21-2008 21:25:16
As long as it's got the sock type, it'll fit. It uses a filter for a 7000 series Allis Chalmers- the dealer looked at me with a funny eye when I only asked for one of those filters as the AC's use 2 filters.
