S55 HC starting
Duke55
05-18-2008 07:39:48
When I step on the pedal to start my S55 gas, 6volt system, nothing happens. Key is on. Battery is charged. Just wont go. I can pull start it fine, runs great. Turn it off, and try to kick start it, and just nothing. I put my volt meter on the starter post, and it reads 6 volts. I am suspecting something in the starter, and I was hoping to get some things to do/look for here. I did take the lever connector off the starter and I think the contacts do look ok. I should have put the (-) battery to the main starter post to see if the starter jumped, I thought of that after. I will be doing that today when the rain stops.
Anything else?
Matt Kane
05-18-2008 11:38:23
 Re: S55 HC starting in reply to Duke55, 05-18-2008 07:39:48
If you find its your starter, If its the brushes its an easy fix. Mine had 2 brushes gone and it wouldn't start. I went to autozone spent 4.00 and was back in business.
Duker55
05-19-2008 06:10:21
 Re: S55 HC starting in reply to Matt Kane, 05-18-2008 11:38:23
I have the starter on the bench now. I I couldnt get it to energize at all with a battery and cables. Wouldnt jump at all. I have a friend how may be able to help me diagnose teh starter, so I may be in good shape. I see Value Bilt sells new reconds for 130$ too. Hopes its the 4$ brushes you talk about.
M H pete
05-18-2008 10:43:25
Look for starter bolt going in to far and hitting fly wheel and locking up engine
Duke 55
05-18-2008 11:33:20
 Re: S55 HC starting in reply to M H pete, 05-18-2008 10:43:25
OK. I am a poor mechanic at best, and electrics are my worst, but I am thinking that you mean pull the starter, and see if there is a bind there. So today I will pull starter, looks like three bolts. And see what we shall see.
Thanks
