550 Hydraulics (1963)
Mark Trachy
05-14-2008 10:00:24
My hydraulics stopped working while I was splitting logs. I suspect that it is the relief valve, however, and here is where you will laugh, I am not sure if there is a relief valve for the external hydraulics, or if I ony have an internal relief valve. What would an external relief valve look like, and how can I test it?
Thanks
J Schwiebert
05-14-2008 12:30:42
 Re: 550 Hydraulics (1963) in reply to Mark Trachy, 05-14-2008 10:00:24
If you have the Oliver external valve it has a relief valve built in the inside. It is the first thing to suspect even if your 3 point does not work.
Mark Trachy
06-02-2008 09:31:21
 Re: 550 Hydraulics (1963) in reply to J Schwiebert, 05-14-2008 12:30:42
How do you troubleshoot the relief valve? I have taken the external control off and i can't figure out how to check the relief valve.
Thanks
Mark Trachy
05-15-2008 12:10:43
third party image
I have a picture of my hydraulics set up and I would like to email it to you. Is that okay?
