Clutch?
Hoss in Me
05-14-2008 05:35:51
Buddy of mine has a stock ollie 88 diesel.Clutch feels good but power isnt going tthrough tranny,any sugestions?She gotta be split? Thanx,Hoss
Dave Sherburne NY
05-14-2008 18:08:37
 Re: Clutch? in reply to Hoss in Me, 05-14-2008 05:35:51
It can be done without moving engine, but you have to remove steering, gas tank just about everything above bell housing which I find is easier
Hoss in Me
05-14-2008 11:06:02
Ill have him get a book on it.I durn sure aint gonna buy one.Thanx guys,Hoss
J Schwiebert
05-14-2008 07:41:07
Look at the coupler. Slide it ahead and look at splines on transmission shaft. If you have a replacement with a disk that has the torsional springs they will also fly apart. Like Brad said no need to split it. in fact have done many without removing engine. You do need a book.
bradk
05-14-2008 05:52:41
Is the coupler at rear of bell housing stripped/bolt missing?
If the clutch is confirmed slipping,only the engine has to come out.Pretty easy.Once you pull PTO shaft from rear, it's like pulling an engine from an older car or truck.
I'd strongly recommend a repair manual.Ebay has them.
bradk
05-14-2008 05:51:49
If the clutch is confirmed slipping,only the engine has to come out.Pretty easy.Once you pull PTO shaft from rear, it"s like pulling an engine from an older car or truck.
