35 OIL LEAK
ROBOCOP
05-09-2008 11:25:55
I recently aquired an old cockshutt 35. Got her going but discovered when it gets warm the oil literaly runs out around the rear seal. I imagine that the crank surface is worn on the seal, does anyone know if I can get a speedy sleeve to match up with the rear seal to go on the crank? would this even be possible? thanks.
ROBOCOP
05-12-2008 13:38:06
 Re: 35 OIL LEAK in reply to ROBOCOP, 05-09-2008 11:25:55
Thanks guys. I will check my oil pan first. Maybe my problem there.
Irv Buttray
05-11-2008 12:20:58
first of all are you 100% sure it is the rear main seal or could it be rear oil pan seal. rear main seal is a large double lip seal that does were and are available. In fact I have new/old stock better seal then what you will buy at parts house. Also the oil pan is a 4 piece seal that is side seals are seperate and the end seals come with a rubber seal. I also have these seals. You should be able to take new seal and get a speedy sleeve if crank actually is worn. Phil most likely also has these. I do have alot of Cockshutt parts and have acsess to these hard to fing Hercules parts.
c35
05-10-2008 06:53:41
Phil Heisey likely knows if this is available or not. He is the Cockshutt parts guru. He's very good to deal with.
Phil Heisey 215-256-8651 FAX 215-256-1203
