Hesston 566 fuel issue
utah
05-05-2008 05:40:37
I have a Hesston 566 tractor that has presistent fuel problems. It is associated with the tank as the tractor quits when when usually plowing or discing and at a slight angle. The usual procedure is to take the fuel line apart loosen the tank cap and blow air back into the tank to clear the line. There does not appear to be anything in the tank that would block the line. Has anyone experienced sa similar problem?
