Oliver 550 grill question
gordey
05-04-2008 18:53:12
Is the grill schroud the same on a checkerboard model as a bar grill model?
gordey
05-04-2008 21:14:23
 Re: Oliver 550 grill question in reply to gordey, 05-04-2008 18:53:12
I mean the peice that holds the grill and has the oval Oliver logo on it.
Chris Van
05-04-2008 21:58:13
 Re: Oliver 550 grill question in reply to gordey, 05-04-2008 21:14:23
Oh, that's the same throughout production, until you get the extra hole for the power steering reservoir filler.
Chris Van
05-04-2008 20:43:40
If you mean the shroud that supports the radiator (and is an integral part of it) within which the fan spins, then NO they are not the same...or perhaps better to say that the radiators differ. The early rads are a bit taller (longer by nearly an inch at the bottom reservoir - and the fan indent sits lower too).
I just purchased two new 550 rads (Rickert Implement have them on eBay and Korves Oliver have the same ones). It did not fit my 1958 but it did fit the 1969 one.
On the early one, the bolt holes all lined up perfectly, but the fan could not spin freely inside the cowl. It rubbed severely at the bottom. NOT a noise you want to hear for long!
I will post the serial number of the change tomorrow....but probably the same as when the engines changed.
