Oliver 1655 oil pressure
DABOT
04-27-2008 16:30:42
I've returned for advice. Pressure guage at location of oil guage line tested 95# at idle. Increasing rpm's maxed out the guage which goes to 100#. Concerned about using tractor until I know I wont harm it. Thanks J. or anyone else with input.
IA Farmer
04-27-2008 19:37:14
 Re: Oliver 1655 oil pressure in reply to DABOT, 04-27-2008 16:30:42
Seems pretty high to me. Maybe try a shorter spring at the relief valve.
DABOT
04-27-2008 17:45:56
I'll have to check with mechanic to see which oil pump we used.
Larry from Maryland
04-28-2008 06:56:07
 Re: Oliver 1655 oil pressure in reply to DABOT, 04-27-2008 17:45:56
Sounds like someone over tighted the relief valve on the pump. Years ago i had an oliver mechnic in an oliver dealer tell me to tighten up the plug all the way in then install the cotter pin. I had the same problem you have now. The book says to tighen the plug only untill you can get the cotter pin in. It makes a big differance. The fellow who told me this had 25 years working on oliver tractors and i was working on my first so i did what he said.
