Oliver 1800 Diesel Pto Rate
Pat Findlay
04-26-2008 10:22:13
Hello. I have a Oliver 1800 Diesel and was wondering the PTO rate. I want to attached a square baler and need to find out the PTO rate. I am waiting for a manual but as right know it has not arrived. Thanks for the help.
ksampson
04-26-2008 13:25:05
 Re: Oliver 1800 Diesel Pto Rate in reply to Pat Findlay, 04-26-2008 10:22:13
540
J Schwiebert
04-26-2008 10:58:36
Make sure your clutch is adjusted properly. Check the over-center snap.
J Schwiebert
04-26-2008 10:48:56
1800 Olivers had rated PTO speed at rated engine speed. So if the tractor is an A series 1800 the rated engine speed is 2000 RPM. If a B or C series rated PTO speed is at 2200.
Pat Findlay
04-26-2008 12:43:52
 Re: Oliver 1800 Diesel Pto Rate in reply to J Schwiebert, 04-26-2008 10:48:56
Thanks for your reply. So would that make the PTO a 540/rpm or 1000/rpm...?
J Schwiebert
04-26-2008 16:51:12
 Re: Oliver 1800 Diesel Pto Rate in reply to Pat Findlay, 04-26-2008 12:43:52
Like was mentioned in the one above post, the PTO will be 540. But 1000 was an option. Take a look at the PTO shaft. 540 is a 6 spline shaft 1000 is a 21 spline shaft.
