Cockshutt Hercules Perkins water pumps.
J Schwiebert
04-26-2008 05:35:50
As you know Hercules engines were used by more than Cockshutt & Oliver applications. I have one here off of a GO-339 engine. I wanted to compare casting numbers. Mine is out of a forklift. What are the casting numbers for the tractor applications? Thanks in advance. J.
J. Schwiebert
04-26-2008 10:46:55
 Re: Cockshutt Hercules Perkins water pumps. in reply to J Schwiebert, 04-26-2008 05:35:50
Remember the numbers cast or stamped on the pump will be Hercules part numbers. The MKO is a Cockshutt number. Example: 198 Hercules. The part number for a kit will be different for a Cockshutt than for an Oliver OC-9 crawler. But the kit or parts may be identical, yet the castings can and may be different. Wait till you try Continental F model water pumps or in todays world, some 300 series engines John Deere water pumps. You can also have left hand water pumps for industrial and marine applications. J.
Jim Joseph
04-26-2008 10:32:55
Found a number stamped on 35 pump, 128122 I have a parts book that shows a part number for complete pump as MKO-211 but the part number probably don't mean much these days. This has became quite intersting. Jim
