Oliver 550 gas-oil buzzer is going off
cdm
04-25-2008 15:48:59
My Oliver 550 gas,the oil buzzer is going off continuously. Oil level right up to full, tractors been running fine. I can use remote starter switch to start tractor, but would like to fix the buzzing problem so that key switch works. Any suggestions?
Thank you in advance
J Schwiebert
04-26-2008 10:56:33
 Re: Oliver 550 gas-oil buzzer is going off in reply to cdm, 04-25-2008 15:48:59
If that wire or sender is grounded anywhere it will buzz. How much oil pressure do you have?
Chris Van der Vyver
04-26-2008 10:41:04
Maybe the oil sender is broken or disconnected? Look under oil filter.
wmthrower
04-28-2008 05:16:30
 Re: Oliver 550 gas-oil buzzer is going off in reply to Chris Van der Vyver, 04-26-2008 10:41:04
Pardon my ignorance, but being the new owner of a 550 (less than 1 week) I didn't realize that there was an oil pressure buzzer. Where is it located?
Do any of the 550's have an oil pressure guage? Mine does not. Just the Tach/hour meter and fuel/temp guage.
Chris Van der Vyver
04-28-2008 05:34:58
 Re: Oliver 550 gas-oil buzzer is going off in reply to wmthrower, 04-28-2008 05:16:30
If you remove the hood by undoing the four wing nuts, you will see the buzzer in front of instrument panel behind gas tank. It will be connected to the oil pressure sender with a pale blue wire if it is original wiring....and also connected to oil pressure warning light.
No, sadly 550s do not have a separate oil pressure gauge.
My buzzer went off briefly the day I changed the electrics from negative back to positive ground and it has been fine ever since.
wmthrower
04-28-2008 07:04:31
 Re: Oliver 550 gas-oil buzzer is going off in reply to Chris Van der Vyver, 04-28-2008 05:34:58
Thanks for the answer Chris. I believe that mine is still the original wiring. Is this the same buzzer that comes on when I first turn the key to start the tractor?
