PTO on 1750 oliver
newtod
04-23-2008 19:32:47
CAN ANYONE TELL ME WHY MY PTO WILL NOT QUIT TURNING WHEN THE LEVER IS DISENGAGED. I TRIED ADJUSTING THE LEAKAGE ON THE LEVER NO HELP. IF I CAN GET PLUG OUT I GOING TO CHECK PTO CLUTCH ADJUSTMENT. ANYONE ELSE HAVE ANY IDEAS OR ANY OTHER THINGS I MIGHT CHECK OR TEST TO NARROW DOWN THE PROBLEM. WHEN I BOUGHT THE TRACTOR IT DID NOT TURN WHEN DISENGAGED BUT STARTED AFTERWARDS. ANY INFO WOULD BE GREATLY APPRECIATED.
olivercow
04-23-2008 21:10:16
 Re: PTO on 1750 oliver in reply to newtod, 04-23-2008 19:32:47
Adjustments for left or right hand lever are about the same outcome. First, did you run the pto with a good snap engagement ? Because if you run it loose you"ve already warped the clutch plates and you need to replace the clutch and seperator plates. Then if it snaps good all you need to do is adjust the stop bolt as you hold the lever down gently. You can call me for any further explanation. ph# 830-583-3025.
