Oliver 550 - Got my Replacement Pump
MapleStone
04-19-2008 05:41:18
For those who've read about my hydraulic problems and offered help, I just wanted you to know that I've got a replacement hydraulic pump and it's currently at the hydraulic shop waiting for a new bearing. The guy at the hydraulic shop is super nice and he showed me everything he was doing. It didn't need much but he polished some of the wear off the cast pieces and the rotor and put new o-rings in it. The bearing will be in on Monday and I should be able to spend some time and get my tractor back together on Tuesday.
I took valves out and looked at everything and replaced o-rings and everything looked good. Hopefully when I get the pump on and back together I'll be all set.
Thanks to everyone who offered help and suggestions.
J Schwiebert
04-19-2008 05:59:41
 Re: Oliver 550 - Got my Replacement Pump in reply to MapleStone, 04-19-2008 05:41:18
Make sure you at leat take the hydra-stat spools apart and look at the disassembled valves with a maginfying glass and test them for opening pressure before you assemble them. No if and or buts about it!. J.
