Oliver Suitcase Weights??
oliverhick
04-19-2008 04:54:42
Does anyone know if oliver made any kind of suitcase weights at anytime. I have never seen any and i was just wondering if they exist. i know they have the wheel weights and the front slab weights but thats all i know of.
jdputtputt
04-19-2008 13:58:04
 Re: Oliver Suitcase Weights?? in reply to oliverhick, 04-19-2008 04:54:42
Now this may upset a lot of you but yes Oliver did sell these just as pictured but they actually are a MM wieght that was first used on late M670, G1000 and G900 tractors. MM had exactly that cast into them. A lot of guys will buy white, MM or Ollies and grind them off and put them in the middle
j meyer
04-19-2008 19:58:30
 Re: Oliver Suitcase Weights?? in reply to jdputtputt, 04-19-2008 13:58:04
My weights are the later ones, and they are correct for either a moline or an oliver. This was done thru the consolidation of White's agricultural companies. The "MM" weights were 10A24132, and my weights pictured are 20-0007856. They are the very similar castings, but are a different weight. Also the "MM" weights come in a few different varieties as well. I believe all G900, G1000, and so on were to have "MM" stamped weights on them originally....and probably around 1972 they would have made the blank weights(20-0007856) as the standard weight for both brands. The weights are as Oliver as Molines 1971 tractor lineup:)(thats a thinker!)
j meyer
04-19-2008 07:13:20
third party image
third party image
what would you like to know? I got two sets of them.
MCL
04-19-2008 05:18:53
Yes they did in the 1970's. I am sure someone who knows more than I do will elaborate.
