G1355 engine repair
MikeOwi
04-16-2008 18:10:55
We fired up the G1355 and noticed a definite misfire on #2 piston. You could feel the vibration from the misfire. Now is it feasible to just repair the first two cylinders or am I looking at redoing the entire engine. My hired man used ether on it last year and said it didn't run well afterwards. We are parking it for now since I have others to use in the meantime. Any ideas would be appreciated. Thanks in advance. It only has 2600 hours on it.
TERRY FOSS
04-17-2008 05:51:11
 Re: G1355 engine repair in reply to MikeOwi, 04-16-2008 18:10:55
CHECK THE PUSH TUBES FOR THE VAVLES .THEY WILL BEND IF TO MUCH ETHER IS USED .
m kuhns
04-17-2008 02:38:29
Does it have a lot of blowby? For the amount of work required it sure doesn't pay to do 2 cylinders. Did you check valve adjustments? Ether shouldn't really be a problem unless it was abused locking the engine up. The stuff now a days isn't too powerful.
