1650 Hydraulic Pump Leak
Adam- WI
04-16-2008 14:38:15
I found the problem on my 1650. The seal on the pump was torn. The shaft looks in very good condition as do the gears. Very little play in the gear shafts, so now I have to put it back together with all new seals and she should be good as new.
J Schwiebert
04-16-2008 15:29:24
 Re: 1650 Hydraulic Pump Leak in reply to Adam- WI, 04-16-2008 14:38:15
Before you do that while the pump is apart, push the gears toward the pressure side of the center plate. How large a feeler gauge can you stick between the side of the gears and the plate. Looking at stuf and measuring clearance are two different things. The gears ands shafts normally look good. The problem is with the bushings and the aluminum center plate. J.
Adam- WI
04-17-2008 06:22:53
 Re: 1650 Hydraulic Pump Leak in reply to J Schwiebert, 04-16-2008 15:29:24
J, thank you for all your help on this. Which side is the pressure side and how much clearance should there be?
J Schwiebert
04-18-2008 16:37:49
 Re: 1650 Hydraulic Pump Leak in reply to Adam- WI, 04-17-2008 06:22:53
Push the gears toward the suction side (side with largest port) Slide a feeler gauge between the gears and the center plate. Tell us what you have. J.
