1750 Carb problems
Andy Mo
04-15-2008 18:32:29
I have a 1750 with a USX 37 carb. I'm trying to adjust the carburator.The power jet adjustment makes no difference,won't lean out or burn too rich. Carb is very clean and seems in good order.I'm coming from the orange side and they sure don't have a carb like this.Thanks for your help. Andy
J Schwiebert
04-16-2008 03:38:16
 Re: 1750 Carb problems in reply to Andy Mo, 04-15-2008 18:32:29
Ah yes good carburetor. You will need a diaphram kit for sure, maybe a new power jet which has to be purchased from a Deere dealer and you must have a vacuum gauge to test it before you put it back on the tractor. Later with more details. I will probably send you an e-mail. J.
Andy Mo
04-16-2008 19:25:10
 Re: 1750 Carb problems in reply to J Schwiebert, 04-16-2008 03:38:16
I would appreciate any more info you might have. Thanks
