550 auxilary valve problem
MAX -KY
04-15-2008 17:41:18
Went to use my 550 to disc the garden but it would not pick up the 8 ft. wheel disc. Fluid level ok three point works but it will not lift the disc with the cylinder. Hooked the disc to my 1600 and nothing wrong with cylinder. I think the o-rings between valve and hydraulic housing may be blown. Any ideas appreciated.
Matt Kane
04-16-2008 13:11:48
 Re: 550 auxilary valve problem in reply to MAX -KY, 04-15-2008 17:41:18
There is a relief valve inside the unit. I would suspect thats theres something behind the ball and seat. Remove it from the tractor, take it apart, clean everything and then replace the o-rings when you put it back on. Have you tried a load on the 3-point yet? All fluid runs through that valve. If you have no pressure for the aux, then you shouldn't have alot of pressure for the 3-point. Hope this helps, Matt
