550 front axel pivit pin grease
Kevin Roberson
04-07-2008 18:02:16
All,
I can not get grease into the zirc to grease the pivot pin where the front axel attaches to the frame. I replaced the zirc fitting and still can not get any grease ito the joint. What should I do? I appreciate any help, as I am a novice mechanic and have learned a lot from this forum.
KR
J. Mash
04-07-2008 21:08:19
 Re: 550 front axel pivit pin grease in reply to Kevin Roberson, 04-07-2008 18:02:16
Heat the pin real good with a torch
MapleStone
04-07-2008 18:41:38
Apply some heat to the casing and pump grease in at the same time.
Maybe jack the front of the tractor off the ground to remove any pressure as well.
