770 Injection Pump Timing
Wrenchbender
04-07-2008 17:39:38
I need to know the pump timing for a late 770 with a Roosa Master pump. I only have a I&T manual for 770-880 and it only lists the PSB pump. My 1600-50 manual says 7 degrees BTDC for Roosa Master without timing advance, thought a 770 might be different.
TIA, WB.
J Schwiebert
04-08-2008 03:45:49
 Re: 770 Injection Pump Timing in reply to Wrenchbender, 04-07-2008 17:39:38
Well you are close. We were given condensed spec sheets one year for tune up specs./770 Diesel is listed at 6 degrees BTDC. J.
Wrenchbender
04-08-2008 09:02:13
 Re: 770 Injection Pump Timing in reply to J Schwiebert, 04-08-2008 03:45:49
Thank You John!
