59A loader and super 55 questions
Josh in Pa
04-01-2008 05:13:32
I"m looking at a super 55 with 59a loader. How much can this loader lift? I am wanting to handle the occasional round bale, which could be 800+ lbs. The tractor hydraulics are used to run the loader.
Josh
Mike (WA)
04-02-2008 08:51:47
 Re: 59A loader and super 55 questions in reply to Josh in Pa, 04-01-2008 05:13:32
Those little rigs are in pretty good demand- if its decent, and priced accordingly, you should be able to get a big enough tractor and loader to do the job right, for nearly the same money. I agree with the others- its too big a job for that size tractor- tractor too light, and front end not strong enough. Hate to see one all busted, welded and cobbled up- they're not making them anymore!
oliver_t
04-01-2008 15:55:29
I bought a S55 with 59A loader. Tried to use it for smaller round bales, about 500 lbs. It lifted OK but front end is way too light. Great little loader for manure.
John
Matt Kane
04-01-2008 13:00:04
I don"t know if I would push a super 55 with that much weight on the front. The spindles are pretty small, and the front end will get alot of damage. If its a solid front axle, then I would consider it. Also with the loader running off of factory hydraulics, it would be a little slow. I wouldn"t try it. Some of those round bales are heavy!
