880 olivers
STEVE @ BARB
03-31-2008 17:57:12
would like to know where i could find out about casting numbers on tubs and rear ends housing ,and if there were any 880 that had a supper tub and or a supper rear end. thanks steve
rrlund
04-01-2008 06:50:17
 Re: 880 olivers in reply to STEVE @ BARB, 03-31-2008 17:57:12
There's a casting code that's actually a date code on the underside of the rearend housing. I suppose that would tell you if it was cast before the introduction of the 880s.
J Schwiebert
03-31-2008 18:30:02
I don't know where you are going with this but internally there is not much difference between a later Super 88 and a 1958 880 except check the code as most of the 880's will have the slow speed ring and pinon.
