Re. Can't start Oliver 77RC update
Male Gayle
09-27-1998 20:41:58
Hey, guys, thanks for all your replies. I removed the starter and spun it with the battery charger 6 volt starting circuit. The bendix drive appeared to move as it's supposed to. I reinstalled the starter and attempted to engage by using the battery charnger 6 volt starting circuit again. Hum, but no turning of the engine. Next tried the 12 volt starting circuit. Success! The engine turned over easily. Tried the 6 volt system again. Again, the hum but no turning the engine. Not sure what the problem is, but as I have removed the gas tank for rust repair, I haven't tried to get the engine to run, yet. I will have the gas tank re-installed in 48 hours and will attempt to start the old girl then. Again, thanks for all you guys' help. I'll keep you posted.
Dennis
09-28-1998 16:37:23
 Re: re. Can't start Oliver 77RC update in reply to Male Gayle, 09-27-1998 20:41:58
: Hey, guys, thanks for all your replies. I removed the starter and spun it with the battery charger 6 volt starting circuit. The bendix drive appeared to move as it's supposed to. I reinstalled the starter and attempted to engage by using the battery charnger 6 volt starting circuit again. Hum, but no turning of the engine. Next tried the 12 volt starting circuit. Success! The engine turned over easily. Tried the 6 volt system again. Again, the hum but no turning the engine. Not sure what the problem is, but as I have removed the gas tank for rust repair, I haven't tried to get the engine to run, yet. I will have the gas tank re-installed in 48 hours and will attempt to start the old girl then. Again, thanks for all you guys' help. I'll keep you posted.
My 6 volt starter on my Super 55 is a lot happier with 12 volts also. You might take a look at your brushes. I just replaced mine as well as the spring clips that hold the brushes tight. It runs like a new starter.
Dennis
09-28-1998 16:37:11
Von W.C. Ohio
09-28-1998 19:24:13
 Re: Re: re. Can't start Oliver 77RC update in reply to Dennis, 09-28-1998 16:37:11
: : Hey, guys, thanks for all your replies. I removed the starter and spun it with the battery charger 6 volt starting circuit. The bendix drive appeared to move as it's supposed to. I reinstalled the starter and attempted to engage by using the battery charnger 6 volt starting circuit again. Hum, but no turning of the engine. Next tried the 12 volt starting circuit. Success! The engine turned over easily. Tried the 6 volt system again. Again, the hum but no turning the engine. Not sure what the problem is, but as I have removed the gas tank for rust repair, I haven't tried to get the engine to run, yet. I will have the gas tank re-installed in 48 hours and will attempt to start the old girl then. Again, thanks for all you guys' help. I'll keep you posted.
: My 6 volt starter on my Super 55 is a lot happier with 12 volts also. You might take a look at your brushes. I just replaced mine as well as the spring clips that hold the brushes tight. It runs like a new starter.
I converted my 1955 Oliver Super 77 over to a 12 volt negative ground with an alternator from a 6 volt positive ground with a generator when I overhauled it in 1992 and put M&W pistons and sleeves in it. I am still using the 6 volt starter with no problems. The 6 volt starter running on 12 volts should only draw 1/2 the current it did at 6 volts so it should last a long time. (double the voltage and halve the current) The large current flow is what will burn things up. Besides it does not have to run very long on 12 to start versus the slow cranking it did at 6. If you get cold weather and a fresh overhaul you will definitely want 12 volts.
Good luck getting it started !
Von W.C. Ohio
