Front wheel bearings for 1650 Cockshutt
Bruce Hopf
03-29-2008 21:27:36
I was greasing my 1650 Cockshutt yesterday, and I noticed there no grease fillings for the front wheel bearings Are they filled with gear oil, and if so how do you go about checking them? I noticed a plug inside the wheel, on the hub. I take it that is where I drain, and refill. Do I use 80W90 gear oil in there, if they are lubricated with oil? I appreciate all your advice.
Thanks. Bruce.
super99
03-30-2008 03:52:07
 Re: Front wheel bearings for 1650 Cockshutt in reply to Bruce Hopf, 03-29-2008 21:27:36
Bruce, Take out the pipe plug, and get a reducer that goes from size of pipe plug down to fit a grease zerk. Screw the reducer with the zerk into the hub, loosen the bolt on the outside cover a little, pump grease into hub untill it comes out around the loose cover. Tighten the cover, remove the reducer and put the plug back in and go to the other side and repeat. Or you could just drill and tap threads in a pipe plug to fit a grease zerk. Chris
