FYI - Cessna hydraulic pump (550 - 2/44)
Chris Van
03-29-2008 13:45:52
From manual:
Pump should operate at 17 gpm if in good condition, but have not measured it.
Max operating pressure is 2250 psi.
Chris Van
04-17-2008 09:16:02
 Re: Cessna hydraulic pump (550 - 2/44) in reply to Chris Van, 03-29-2008 13:45:52
Latest update. I have replaced all seals, and will test it for pressure and gpm when I get the engine fired up again.
Failing that, I have located [amazing this!] new/old stock gears/shafts and body center plate from Maibach tractor.
That should help if another rebuild is called for.
