Model 30 Ross steering gear lube
cj in wisconsin
03-27-2008 10:18:10
I am in the process of installing the steering gear on my 30. The question is, do I use 80w90 in it or grease? I have checked 3 of them and 1 has gear oil, and two have grease, I am assuming it should have gear oil and the ones with grease probably leaked. My manual does not show what type it takes.
P Heisey-Harleysvill
03-29-2008 04:41:35
 Re: Model 30 Ross steering gear lube in reply to cj in wisconsin, 03-27-2008 10:18:10
Hi cj in wisconsin,
Tim in NB & c35 are right. EP 140 gear oil was the original spec.
More recently, some prefer to use JOHN DEERE, (YES, JD) combine SPECIAL CORN HEAD GREASE (from cartridge tube) # AN102562. It's viscosity is between oil and grease and will not seap out like the oil if everything is not perfect.
Phil Heisey 215-256-8651 FAX 215-256-1203
Tim in NB
03-27-2008 13:34:04
c35 is right! Cockshutt originally called for 140 weight in the 30 gear boxes. People put grease in them when the seals go bad. Btw it holds 2-1/2 imperial pints.
c35
03-27-2008 13:17:09
Takes 140w100 or simialar, you can get a quart of it at most auto supply places.
