310 waukesha diesel intermittent start
outthere
03-22-2008 07:59:21
Tractor: Oliver 1850, repowered with 310 series c waukesha diesel. I rewired the starter put in a new key switch. Then the spring that holds the tension on the starter armature broke. Put it back on. Now I can hear the starter spinning, the armature pulls, but the starter only engages about every 3 or 4 key turns. I have adjusted the linkage on the armature but it only makes the problem worse. Any ideas out there?
Some of the parts may be wrong any corrections would be helpful. Thank You
outthere
03-22-2008 18:39:38
 Re: 310 waukesha diesel intermittent start in reply to outthere, 03-22-2008 07:59:21
starter is a delco-remy 11413088
Larry from Maryland
03-22-2008 09:01:58
I think you mean selonoid not armature.The starter drive clutch could be going bad.
outthere
03-22-2008 18:05:30
 Re: 310 waukesha diesel intermittent start in reply to Larry from Maryland, 03-22-2008 09:01:58
Yes you are right. The solenoid on my starter sits on top and has a lever coming out of the rear - it is open not the enclosed type that the 1850 has.
