I'm thinking of installing a different motor ina 30
Andy Mn
03-21-2008 11:10:02
Need a motor and they're hard to find. Just wondering if there's a certain motor that would fit in a 30 without a whole lot of trouble.
P Heisey-Harleysvill
03-22-2008 02:40:42
 Re: I'm thinking of installing a different motor ina 30 in reply to Andy Mn, 03-21-2008 11:10:02
Anday Mn,
I talked with a guy in Ontario, CANADA last week that installed a Chevy Celebrity 2.5 4 cyl. engine in a COCKSHUTT 30. He did this several years ago and uses it on a regular basis for blowing snow. Following are a few of his comments:
It fit in easily. The Chevy fly wheel worked after honing out the holes slightly,
The steering shaft was rerouted to the opposite side of the engine and connected to a late 70's Plymouth Volarie / Dodge Aspen power steering / gear that went right in replacing the original COCKSHUTT/ ROSS gear. The original COCKSHUTT radiator was used with the installation of an electric fan.
I have the guy's name and phone number if needed.
Phil Heisey 215-256-8651 FAX 215-256-1203
J Schwiebert
03-21-2008 12:00:53
What is the problem with old engine?
Andy Mn
03-21-2008 12:18:16
 Re: I'm thinking of installing a different motor ina 30 in reply to J Schwiebert, 03-21-2008 12:00:53
It came in as a PARTS tractor missing head and manifolds , sat outside many years , there was weeds growing in the cylinders ! And water leaked past the pistons filling the oil pan and later rusting a hole in the pan , draining the water . Any idea how many years that would take . Anyway there's a crack between the cylinders and one sleeve is broken .
rrlund
03-21-2008 12:53:05
 Re: I'm thinking of installing a different motor ina 30 in reply to Andy Mn, 03-21-2008 12:18:16
Back when I drove milk truck in the early 70s,there was a Cockshutt 30 in one of the neighborhoods where I hauled that had a V8 in it. Never saw it up close,but I used to see it on the road now and then hauling wagons. Had all the original sheet metal and 2 Farmall M style mufflers. that thing looked excellent.
Andy Mn
03-21-2008 13:28:31
 Re: I'm thinking of installing a different motor ina 30 in reply to rrlund, 03-21-2008 12:53:05
Huh , that's interesting , a V8 , Didn't think it would fit with the steering shaft going alongside the block . like to see that. Or maybe it was a 40 or 50 . They had the steering up above like the Farmall
rrlund
03-22-2008 07:50:57
 Re: I'm thinking of installing a different motor ina 30 in reply to Andy Mn, 03-21-2008 13:28:31
That could have been. It's been 35 years. The mind ain't what it used to be.
Larry from Maryland
03-21-2008 16:49:55
I would guess an allis combine engine would be easy to find and close to working.
