OC-3 engine parts
Eric Schultz
03-20-2008 11:06:07
Anyone know where you engine parts for a OC-3 and other Oliver engines?I have a chance to get a unit with a locked up engine.Still has antifreeze coolant in it and the oils OK.
Thanks in advance, Eric
J Schwiebert
03-20-2008 13:13:14
 Re: OC-3 engine parts in reply to Eric Schultz, 03-20-2008 11:06:07
Jerry Biro is the source for obsolete Hercules parts. If someone answers Hercules they will refer you to Jerry. They are only into Military engines. They are also collectorsa. Jerry is also an Oliver crawler collector, I will look up his number later. He is east of Columbus Ohio. Now some parts are available through Napa and others. The key thing to look at is main bearings. Neither F-M or Clevite have them because they did not make some of them to start with. Now what other Oliver engines are you talking about? Are they Oliver or more Hercules?
Eric Schultz
03-20-2008 13:50:37
 Re: OC-3 engine parts in reply to J Schwiebert, 03-20-2008 13:13:14
I have an Oliver 66 Row Crop narrow front (1947?)that needs gasgets ,seals, ect.I haven't looked much for these parts yet,they should be easier to find than OC-3 parts.
Thanks,Eric
J Schwiebert
03-21-2008 12:02:38
 Re: OC-3 engine parts in reply to Eric Schultz, 03-20-2008 13:50:37
They will be. The 66 had not ben built yet in 1947 so it is somewhat newer. J.
old
03-20-2008 14:10:29
Zimermans also sells a good number of parts for the old cletracs. Hes where I got manuals etc for the OC-3 I had a couple years ago. I also have an engine that came out of a OC-3 but it needs to be reuilt but other then that its a good engine
