Reply to 1950TMFWD
B A Star
03-19-2008 22:09:25
    This is in reply to an earlier inquiry concerning the gear ratio on a 1950T MFWD.  First we need to determine which of the four front axle pinion shaft and ring gear you have.  Ratios were: 8/41 5.12:1, 7/38 5.43:1, 7/39 5.57:1 or 7/41 5.86:1  The ratio was stamped on the top of the front differential housing.  Should you not be able to find the ratio, let us know and we will instruct you on determining it.  More than likely you have the 8/41 with the tire sizes you have.
    1950T had only one rear pinion and ring gear set and only one gear set for the transfer case.  You stated that you have new 13.6x24 front tires and want to install 18.4x38 rear.  The loaded radius (LR) for the 13.6x24 front is 21.6" and 18.4x38 is 31.3", thus 31.3 divided by 21.6 gives us a ratio of 1.449:1.  Assuming that you have the 8/41 front axle and new tires 1.470 is a match, 1.455 is 1% lead, 1.440 is 2% lead and 1.426 is 3% lead.  1.449 is only about 1 1/2% lead.
    LR is the distance between the center of the axle and the surface the tire is sitting on with normal load.  As you can see tire air pressure will effect LR as will tire wear.  If you raise the tire pressure slightly in the front tire you will increase the lead, 2-3% is desirable.  Also the addition of loads on either the front or rear axle like a heavy three point hitch load or perhaps chemical tanks mounted on the front will effect the match and will have to be adjusted with air pressure to get in the match you need.
1950TMFWD
03-20-2008 19:10:14
 Re: Reply to 1950TMFWD in reply to B A Star, 03-19-2008 22:09:25
Thanks for the info. You were right on, 5.12:1 is stamped on the differential. Glad for your knowledge and obvious experience. Thanks again.
