Oliver 77 Front Tire Size
Jack Behr
03-15-2008 17:32:42
Just got a 77 it has wore out front tires can almost see the air in them they are 550-16 would 600-16 be to big ? It runs drives steers great power steering even stops good. Are these old Olivers a bit noisey whiney in the gears ? I drove one years ago just cant remember the sound. Thanks for any comments or info Jack
MCL
03-16-2008 17:47:44
 Re: Oliver 77 Front Tire Size in reply to Jack Behr, 03-15-2008 17:32:42
We have a 77 with 6.00-16 fronts. They came either way. They all whine in road gear. Some whine in 3,4,6,R2 not unusual. Too much could indicate problem like bad bearing or worn or chipped teeth.
We have a 770 that was really noisy in the "high" set of gears. Turned out to be one gear really pitted with chipped teeth and another gear just pitted. Changed the worse one because it was easy to get at. Left the other one alone. Helped but still has some noise. Just a toy so I don't worry about it.
AB
03-15-2008 21:03:07
6.00-16 will work, anything bigger is tight. yes, they can be a little noisey in the rear end. Around here there was a saying that the John Deere's were put-puts and the Olivers were whiners.
