Help on some sleeves 283 gas
shuttg
03-11-2008 19:25:48
Where is the best place to but sleeves for a 283 gas motor. I am taking the old sleeves out for bigger pistons (4 1/4). But i need new sleeves so i can bore it out larger. Where is the best place to pick some up at. And what brand? Thanks
Lil Red
03-13-2008 05:18:58
 Re: Help on some sleeves 283 gas in reply to shuttg, 03-11-2008 19:25:48
4020 JD will fit with machine work to the block
new kid in town
03-13-2008 17:29:21
 Re: Help on some sleeves 283 gas in reply to Lil Red, 03-13-2008 05:18:58
and the sleeve
shuttg
03-12-2008 18:56:38
Machining is no problem the block is in the shop right now. Just need some sleeves.
Ed Winkle
03-12-2008 07:06:07
I bored an 88 Oliver to 4 inch in 1973. I used JD 4010 gas pistons and milled them down till they fit. A quarter inch more I think would have to be custom made and I saw a lot of failures. Know your piston maker. My compression went from 150 pounds to 260 which really increased my HP. Fuel had to be changed, you can make E-85 work now. Contact Lawrence Gingerich in Plain City Ohio, he has built the best Waukesha's in the country. Everything needs to be custom made by a custom machine operator and this will not be cheap.
J Schwiebert
03-12-2008 07:10:48
 Re: Help on some sleeves 283 gas in reply to Ed Winkle, 03-12-2008 07:06:07
I have seen several of those 4-1/4 bore engines. They had steel sleeves for extra strength. Are you running a diesel head for the cross flow effect?
Ed Winkle
03-12-2008 07:16:40
 Re: Help on some sleeves 283 gas in reply to J Schwiebert, 03-12-2008 07:10:48
No, used the stock head milled with block to be straight. Always wondered about that, heard about it, never did it. Four and a quarter produces a lot of heat in that little block, maybe too much. They were wrenching when we were winning.
new kid in town
03-12-2008 03:36:01
to go 4 1/4" bore, it takes custom sleeves, and the block has to be machined to take the sleeves.
