50 Cockshutt pinion
Buddy Woodson
03-10-2008 19:40:28
Does anyone know if a Cockshutt 30 ring gear and pinion will fit at Cockshutt 50? Anyone have parts books they can look this up? I have one for a 50 but not for a 30, if someone could give me the parts number from a 30 parts book. Thanks
Irv Buttray
03-11-2008 20:49:33
 Re: 50 Cockshutt pinion in reply to Buddy Woodson, 03-10-2008 19:40:28
What do you need I have a lot of used parts? If you really need a part # then rell me what part it is an I will look it up. There was some changes so a serial # may be needed.
Mike (WA)
03-11-2008 08:17:34
35, 40 and 50 are virtually the same tractors, except for the engine, so many parts interchange. 30 is completely different, as is the 20. You're pretty much limited to 30 parts.
J Schwiebert
03-11-2008 05:48:04
What is the part number you need? The rear end for the model 30 was built by Timken. The 50 rear end is a Cockshutt built & designed final drive.
HLW
03-10-2008 21:00:53
Wont fit.The 50 rear end is way beefier than the 30. A rear end from a 40 is the same as 50 I think.
krm
03-11-2008 07:38:56
 Re: 50 Cockshutt pinion in reply to HLW, 03-10-2008 21:00:53
There is one for a 30 on ebay right now.
