Tach drive on 1850 Perkins
oliver maverick
03-09-2008 08:37:42
My tach quit working some time ago and I troubleshooted it down to the 90 degree drive gear were it is installed opposite of the auxilary shaft on the engine. The drive is not turning while the engine is running and I am leary to tear into it any farther without knowing what else might come loose. Any of you ever changed this part out before? Is this an AGCO part or a perkins? Thanks for any advice.
olrusty
03-09-2008 11:54:53
 Re: Tach drive on 1850 Perkins in reply to oliver maverick, 03-09-2008 08:37:42
Here are some pistures to go along with saying. hope this helps.
olrusty
03-09-2008 11:55:59
 Re: Tach drive on 1850 Perkins in reply to olrusty, 03-09-2008 11:54:53
Oops
rrlund
03-09-2008 10:41:42
There's a pin that goes in the horizontal shaft that goes back in there. It looks like it has a small key built in to it the full length. Your cable probably had some moisture froze in it. It CAN be kind of a bear to get the piece out if it twisted too much before it broke. They are available from Agco.
