Oil pan on 1850
RON SCHMIDT
03-07-2008 06:04:05
Need to know if you can replace oil pan on 1850 oliver perkins diesel when engine in frame or do I have to pull engine to do it. Any advice would be appreciated. Many thanks
rrlund
03-07-2008 07:13:47
 Re: Oil pan on 1850 in reply to RON SCHMIDT, 03-07-2008 06:04:05
You can,but it's a ROYAL pain in the neck to get to the front bolts.You need a short 3/8s drive universal with the socket built in as opposed to a universal with a seperate socket.It's even worse to get them started back in if your gasket isn't exactly lined up,and it won't be. I've done it several times,just ain't easy.
