Oliver 2255 with a 3150 Engine
Shaun Murray
03-04-2008 10:53:38
What is a 1974 Oliver 2255 with a 3150 engine worth. It has approximately 5500 hours and has cab, air, heat, duals, front weights and is 2wd. New bias interior tires and the dual are bald. Original paint, so it will need new as it has some minor rusting. Overall a straight tractor.
Field Ready
03-06-2008 17:30:06
 Re: Oliver 2255 with a 3150 Engine in reply to Shaun Murray, 03-04-2008 10:53:38
Auction march 15 might help answer your question. Two 2255's selling at Clymers In. by Olson auctions. David.
e
03-04-2008 21:28:26
Are you mainly going to use it mainly for work or is it just to look at? The only reason I mention this is because collectors are driving the price of these up. If you are looking for a tractor to farm with, keep in mind 2-135's will have more creature/modern comforts for virtually the same money as a 2255. The 2255's are still good machines, but it's something to think about before you shell out $10k for a 2255.
mak
03-04-2008 14:09:24
Most are going for around $10,000 or more. If it has new inside tires, comes with weights and duals, it would be well worth it.
AB
03-04-2008 12:21:30
Ballpark figure $6500 - $8500 sight unseen.
