880 hydraulic pump
NKau
03-03-2008 13:46:38
Well, finally got around to yanking the hydraulic pump to find the source of the disappearing hydraulic fluid. The centerplate seems fine, so I"m assuming the seals are where the fluid was escaping. Who makes the best replacement seals for these? I also need to replace the shaft that drives the hydraulic pump. The splines that the PTO clutches ride on are badly damaged, and the "pressure plate" seems to be in pretty bad shape as well. Any info on the best parts source for this stuff would be greatly appreciated.
Wisconsin Cowman
03-03-2008 16:38:02
 Re: 880 hydraulic pump in reply to NKau, 03-03-2008 13:46:38
Agco dealer would have the parts or get you them. I will give you some part no. tonight.
