Super 55 clutch release bearing install
Super 55
03-02-2008 12:46:44
I came across an interesting item while installing my clutch release bearing. The flexible hose for the grease fitting was not in my parts book, which is an original. I have a different edition that does have it. I have a cast piece for the bearing sleeve, and the ones in the picture don't look exactly like it. Did they have two different sleeves for different years? Another curiosity is someone put a 90 fitting on the sleeve which I don't think was suppose to be there. It was throwing me off as to which way the hose should install. I removed that fitting and installed the hose directly into the casting. Now I have to go buy the fitting that goes through the tractor frame and gets the zerk.
