Cockshutt 540 PTO Use
mf40industrial
03-02-2008 12:42:44
The PTO engagement lever on the 540 has a little clip with a Spring on it that appears to hold it up from falling down (forward). THe clip rests against a stop mounted with two bolts on the side of the tractor. There is a Spring that holds the clip down so it naturally hooks on the stop. When I attempt to engage the pto (pull the clip up and move the lever forward, the spring is in between the clip and the stop and prevents it from moving forward past the stop. Is this one assembled incorrectly or is there something I am missing as how to engage the live pto lever? THanks
J. Wondergem
03-02-2008 17:54:55
 Re: Cockshutt 540 PTO Use in reply to mf40industrial, 03-02-2008 12:42:44
third party image
Here's a pic of the PTO in gear. Spring is in between the lever and catch, without getting in the way.
mf40industrial
03-02-2008 18:03:24
 Re: Cockshutt 540 PTO Use in reply to J. Wondergem, 03-02-2008 17:54:55
ok. Thanks for the detailed photos.
I will try that tomorrow.
J. Wondergem
03-02-2008 17:47:41
third party image
Here's a pic of the lever out of gear.
