Found A Cummins Part Number of White 80 Flywheel
olrusty
02-25-2008 09:33:57
third party image
I did some digging through our Cummins rep here at work and I got the Bill of Material for the Option FW9100. It looks like the one flywheel is no longer available.
Hope This Helps!!
e
03-01-2008 21:37:29
 Re: Found A Cummins Part Number of White 80 Flywheel in reply to olrusty, 02-25-2008 09:33:57
my email should be in your inbox. Thanks!
olrusty
02-25-2008 09:35:52
That didn't Work!
E send me an email and i can send you the PDF file.
Wrenchbender
02-25-2008 10:42:05
 Re: Found A Cummins Part Number of White 80 Flywheel in reply to olrusty, 02-25-2008 09:35:52
I think you will find that the flywheel in option code FW9100 changed from part # 3911425 to 4933476, it's for a 14" clutch. At least that is what I've found out.
I looked up the parts list for the serial # of a conversion I did 18 years ago and the flywheel group for that engine is FW9017. It says 10" nad 11.5" overcenter clutch. So that has me stumped as to what flywheel that is really for. I don't think we would have put a smaller clutch in, it was a 1955. WB.
