Cummins Part Number of White 80 Flywheel
e
02-20-2008 20:28:58
Does anyone know what the cummins part number is for a white 80 flywheel?
Thanks!
Merlin in Rushford
02-21-2008 07:41:57
 Re: Cummins Part Number of White 80 Flywheel in reply to e, 02-20-2008 20:28:58
Hello! The White American 60 and 80 use the same flywheel as the 100 Series and Workhorse tractors, except...AGCO machines-off the outer "pot" ring, to make it a truly "flat" flywheel. This makes the American flywheel 10 pounds lighter (look at the AGCO shipping weights). Just get a Workhorse flywheel. Then, either install a 14-inch clutch (as we did on a 1650 Oliver) or machine the outer ring off and drill/tap new holes to install the 12-inch clutch. Looks like I need to find my Cummins parts book again! The correct flywheel is Cummins Option # FW9100. I hope this helps!
Merlin
Wrenchbender
02-21-2008 08:02:50
 Re: Cummins Part Number of White 80 Flywheel in reply to Merlin in Rushford, 02-21-2008 07:41:57
Merlin, I came up with differnt flywheel part numbers between a 100/120 and an engine bought from Cummins as a kit and put in a 1955. Can you shed some light on this? The Cummins # for the White changed to a new #, but the one on the other is still good in the Cummins system. Thanks, WB.
BM
02-21-2008 05:08:39
Well Thats a good question. We're a cummins and agco dealer and all i can come up with is the agco number. the cummins parts listing for both the 60 and 80 engine serial numbers don't list a flywheel. i have one on the shelf that i ordered from agco years ago in hopes of getting them made reasonably and it dosen't have a single marking on it. agco list is over 1800.00 we usually use the 14" flywheel no matter what conversion we're doing.
e
02-21-2008 09:20:17
 Re: Cummins Part Number of White 80 Flywheel in reply to BM, 02-21-2008 05:08:39
I'm going to give the folks at South Bend Clutch a call and see what they can come up with. I know the 60 and 80 flywheel is an odd duck because I haven't been able to find a cummins number either. I'll let you know what I find.
