Oliver 550 hydraulic lift
Doug Munn
02-20-2008 17:30:33
I am about to replace the bushings & seals on the cross shaft of my lift. Book says to remove the top of the hydraulic chamber and drift the cross shaft out. I understand the mechanics of replacing the bushings & seals but can it be done without removing the top cover?
Thanks...
Doug Munn
02-21-2008 16:26:22
 Re: Oliver 550 hydraulic lift in reply to Doug Munn, 02-20-2008 17:30:33
Thanks Larry, Looks like I am in for the teardown. Pump may need attention anyway.
Larry from md
02-20-2008 18:35:47
You can dig out the seals and replace them without removeing the unit. The bushings can NOT.
