79 White 2-105 hand brake question.
Texas David
02-19-2008 18:07:29
Mine isn't working. I checked the all the linkage and they are functioning. I bled the brake housing and no change. Any ideas what the issue might be. I"d like to have the parts before I tear it apart.
Thanks.
Texas David
02-20-2008 08:05:32
 Re: 79 White 2-105 hand brake question. in reply to Texas David, 02-19-2008 18:07:29
Thanks for the help. Makes perfect sense now that you describe it and I look at the parts manual :-).
Is there a service manual out there for the 105 like there is for other models?
Thanks again.
Stu
02-20-2008 14:34:52
 Re: 79 White 2-105 hand brake question. in reply to Texas David, 02-20-2008 08:05:32
I have seen IT manuals for the Whites on Ebay, but not as often as the Olivers. A 2-105 is pretty much the same tractor as a 1955(other than the perkins). Stu.
kkiowa
02-19-2008 20:51:45
Pop the dust cap off the middle of the brake housings and loosen the 1/2" jam nut . It takes an allen wrench to tighten the screw the jam nut secures. Tighten both sides till you get about four clicks on your park lever. Don't go too tight or the brakes will drag and get hot.
