Is this the correct lift pump for a 550 diesel?
Hauling Earth
02-19-2008 17:16:20
I was told by Korves bros they thought a 77, 88, 770, or 880 diesel lift pump would fit. I found this on ebay. Is this the correct one? HELP!!! I need all I can get. Thanks
Matt Kane
02-20-2008 06:47:31
 Re: Is this the correct lift pump for a 550 diesel? in reply to Hauling Earth, 02-19-2008 17:16:20
third party image
Here is a pic of my Super 55 Diesel lift pump. It was from maibach tractor. I don't have a number on it though.
Mike (WA)
02-19-2008 19:46:33
When my lift pump went south, I tried to either rebuild it or get another- everybody I talked to either rolled their eyes, or didn't even know what I was talking about. I ended up getting an electric fuel pump from NAPA for about 30 bucks, and it works fine.
J Schwiebert
02-19-2008 18:08:25
Look: there were at least 3 or 4 different pumps used. They interchange. I would buy a new one. Other problems include worn linkage and broken springs in the check valves. Yes the ones mentioned will work. Alater one will also work, you just will not have a sediment bowl.
Hauling Earth
02-19-2008 18:29:57
 Re: Is this the correct lift pump for a 550 diesel? in reply to J Schwiebert, 02-19-2008 18:08:25
Would NAPA have a newer style? Does not having the sediment bowl matter? Thanks
Hauling Earth
02-19-2008 18:26:12
I really wanted to buy a new one. I was told you can't find them new anymore. Do you know where I can buy a new one? Roberts Tractor in Ohio said they could rebuild a used one for me but it was pricey. $250. Thanks for all your help. I really appreciate it.
Old Ford Mechanic
02-20-2008 16:39:39
 Re: Is this the correct lift pump for a 550 diesel? in reply to Hauling Earth, 02-19-2008 18:26:12
712-362-2966.Call Larry Harsin in Estherville Iowa.He will be able to help you.
