cockshutt 20
B Wood
02-17-2008 12:46:46
Anyone know the weight of a 1953 cockshutt 20 and the horsepower of the 124 and the 140!!
Heavy Puller
02-18-2008 05:01:46
 it depends in reply to B Wood, 02-17-2008 12:46:46
I have one stripped narrow.no pto,no hyd it weight is 2100 lbs.I also have one with 3 point,wide front,cast wheels with weights it is at 3400 lbs.out of 3 140's on the dyno 26hp smoking-35hp rebuilt hope that helps
B Wood
02-18-2008 15:25:07
 Re: it depends in reply to Heavy Puller, 02-18-2008 05:01:46
OK thanks heavy puller for that info!!
Weldin man
02-17-2008 17:38:12
 Re: cockshutt 20 in reply to B Wood, 02-17-2008 12:46:46
Nebraska tests lists the 20 as weighing 2820 lbs.The 140 Tested at 25.47 drawbar HP and 28.94 Belt Pulley Hp. So few of the 124's were prodced I doubt if they were ever tested.
B Wood
02-18-2008 00:56:17
 Re: cockshutt 20 in reply to Weldin man, 02-17-2008 17:38:12
ok!! thanks weldinman
