1850 or 1855 gas
anderson farms
02-17-2008 09:03:45
There is going to be one of each at a sale this weekend. Both are gas and the 55 has a "swept back" front end what ever that is. I have alawys had the other green but have wanted an oliver for a long time. What are they worth? Are parts hard to get? I will be using the tractor to put up hay and thats about it maybe pulling a 10 foot disc when I put in new hay fields. Any pros or cons? Heard there tough on gas but how bad? Any thing I should look for? Thanks in advance
anderson farms
02-17-2008 18:25:39
 Re: 1850 or 1855 gas in reply to anderson farms, 02-17-2008 09:03:45
Ok boys me and the check book will be going to the sale saturday. Also the have a little super 55 diesel there too.
j meyer
02-17-2008 15:12:23
An 1850/55 gas tractor is alot like a Deere 4020 gas--they are good tractors with thirsty engines when worked hard. Granted I'd rather have the Oliver over the 4020 gas anyday. Anywho, they are a good unit.
bradk
02-17-2008 14:37:57
Both good tractors.The "swept back" fronts are also called under-mount fronts.We have a few fronts like it and like them well.
Someone on here lately said it pretty well. "It's easier to get Oliver parts now then when Oliver was in business".
ejr-IA
02-17-2008 10:33:17
Your talking about a 90+ HP gas engine.For the light jobs it would not be to bad on gas.The swept back front end means the wide front is tucked back ,it has a shorter wheel base something like a wheatland.Parts availability is not a problem yet through a AGCO dealer.Their is a difference in the hydroulics between the two tractors,open and closed system.They are decent trctors if their in good shape.
