Cummins Re-Power Parts: A little hint for you guys...
Merlin in Rushf
02-15-2008 12:48:42
Hello! If you are in need of a flywheel, flywheel housing, oil pan, exhaust manifold, or other expensive parts for the purpose of convering a 6BT automotive engine to an Industrial version, here's a little hint: call Cummins (the Distributors...not the satellite dealerships) and ask for an Off-Engine flywheel or housing. They routinely pull these brand-new parts off of brand-new engines. Get the correct part number, and then add an "OE" in front of the number. I do not have the correct flywheel number, but the Option Code is "FW9100". Back when I was repowering Olivers, I used to get brand-new Off-Engine parts for very reasonable money. I hope this helps!
Merlin
Wrenchbender
02-17-2008 13:33:45
 Re: Cummins Re-Power Parts: A little hint for you guys... in reply to Merlin in Rushford, 02-15-2008 12:48:42
Hey Merlin, Thanks for the advice! WB.
