570 cockshutt main bearings
glen jensen
02-13-2008 18:07:38
searching for .010 main bearings dd298 hercules
Irv Buttray
02-16-2008 00:26:28
 Re: 570 cockshutt main bearings in reply to glen jensen, 02-13-2008 18:07:38
Almost impossible to find them in .010 if you do let me know where! I can mostlikely get you .020 if you have to go this route email me.
glen jensen
02-20-2008 12:49:11
 Re: 570 cockshutt main bearings in reply to Irv Buttray, 02-16-2008 00:26:28
Irv B thanx for responce-pursue the .o2o mains crank dia is 2.5 dd298 herc-no .o10 out there-only std.
J Schwiebert
02-14-2008 12:12:59
A couple of things come to mind. This is a 570 that has not been repowered with a 298 Military engine. Next FYI for you. Both Clevite & F-M discontinued those bearings some years ago. I have been cleaning a little in the evenings and I did find my Clevite print out so there may be a solution if you do not come up with any. Also I know the rods are different for the Military engines and without looking I would gues they use Military Standard parts. It will be the weekend before I do look. Just trying to help. J
glen jensen
02-22-2008 18:17:11
 Re: 570 cockshutt main bearings in reply to J Schwiebert, 02-14-2008 12:12:59
J Schwiebert-thanx for input. would you try to find somthing compatible with my crank on your print out, DD298 hercules 2.5 crank diameter turned .010 . Help is great.
Farmer Jack
02-14-2008 03:53:51
goto herculesengine.com They should be able to help you.
c35
02-14-2008 05:05:48
 Re: 570 cockshutt main bearings in reply to Farmer Jack, 02-14-2008 03:53:51
Phil Heisey 215-256-8651 FAX215-256-1203 has these in stock
c35
02-14-2008 05:05:45
c35
02-14-2008 05:05:42
cj in wisconsin
02-14-2008 05:34:37
 Re: 570 cockshutt main bearings in reply to c35, 02-14-2008 05:05:42
Hey C35 your sssss tttttuttering
c35
02-14-2008 13:20:21
 Re: 570 cockshutt main bearings in reply to cj in wisconsin, 02-14-2008 05:34:37
sticky mouse
