Possible diesel in oil pan on Oliver 550
Hauling Earth
02-10-2008 07:44:09
I recently bought a 1960 Oliver 550 diesel. It appears to be getting diesel in the oil pan. The oil is a little high and it runs off the dipstick. It doesn't have a big oder of diesel. I suspect maybe the fuel pump is leaking and maybe that is the cause. Can anyone give me some guidance. Very appreciated. This a diamond in the ruff that runs very well. Looking forward to getting the little bugs worked out.
J Schwiebert
02-10-2008 08:10:13
 Re: Possible diesel in oil pan on Oliver 550 in reply to Hauling Earth, 02-10-2008 07:44:09
Must still have a Bosch Injection pump? Only 3 places fuel can come in. Lift pump ( number one answer) missfiring cylinder from unburned fuel, Injection pump (leaking o-ring) Now if you have the early Roosa Master without lift pump suspect leaking seal on pump drive shaft. 1960 is the year they changed from Bosch to Roosa master so that information and maybe a serial number would help. J.
Hauling Earth
02-10-2008 08:44:55
 Re: Possible diesel in oil pan on Oliver 550 in reply to J Schwiebert, 02-10-2008 08:10:13
Thanks for your quick response. This is my first Oliver. I have read the forums on here and talked to alot of people and I was convinced, the Oliver Super 55 and the 550 were for me. After I finish this, I want to get a Super 55. Anyway, back to the main subject. The little tag towards the front has 3663AR. The larger tag has: Top Line American Bosch, next line PSB4A-70Y-3797B1, next line 7894069 60444, next line 3663AR. The numbers were hard to read due to paint. Thanks again
